OILS
14 Feb 2013 21:34 #62601 by fast forward
OILS was created by fast forward
going to check & change oils in both front and rear diffs and gearbox / transfer case , which oils do i need some say gl4 others gl5 ect . and roughly how much in each i know till it comes back out of filler plug hole . dont want to over spend at car spares ! over to you brainy lot i await answers . :dry:
if you cant go round it go over it ! or vice versa ?
  • adamatdraycott
15 Feb 2013 14:31 #62666 by adamatdraycott
Replied by adamatdraycott on topic OILS
bigjimny.com/index.php/information/gener...s-and-fluids-v15-283
All the info you require is above.
I bought 5L of each oil and its not quite enough to do the whole job twice
  • reaper
15 Feb 2013 15:39 - 15 Feb 2013 15:42 #62671 by reaper
Replied by reaper on topic OILS
Engine Oil 4.0 litres 10W - 30
Gearbox Oil API GL-4 1.1 litres 75W - 90
Transfer Box Oil API GL-4 0.8 litres 75W - 90
Differential Oil (Front) API GL-5 1.1 litres 80W - 90
Differential Oil (Rear) API GL-5 1.3 litres 80W - 90
Coolant Capacity 4.5 litres
A/T Fluid/Power Steering Dextron IIE 1.1 litres
Brake Fluid DOT3
Last edit: 15 Feb 2013 15:42 by reaper.
  • JivingDaddy
15 Feb 2013 15:47 #62674 by JivingDaddy
Replied by JivingDaddy on topic OILS
Don't forget the golden rule. Check that you can remove the filler plugs before you drain. I still cannot get mine undone!! :(
15 Feb 2013 17:59 #62687 by fast forward
Replied by fast forward on topic OILS
cheers for your replies ;)
17 Feb 2013 21:11 #62935 by fast forward
cheers all done apart from engine oil do we all agree on 10w-30 . before i change it ! :)
