Special Tool?
09 Feb 2013 10:16 #61652 by kirkynut
Replied by kirkynut on topic Special Tool?
If the exhaust isn't blowing why replace it?
  • JivingDaddy
09 Feb 2013 10:32 #61654 by JivingDaddy
Replied by JivingDaddy on topic Special Tool?
Exactly Kirk. I'm just going to sort the rattling heat shield and wait for the rest of the exhaust system to fall apart. Not too long looking at it tho' (probably when the weather improves).
09 Feb 2013 11:35 #61663 by facade
Replied by facade on topic Special Tool?
The catalyst under the passengers feet has a flat heatshield dab welded to edges of the flat flange around the box.
The dab welds pop off, and the shield buzzes at whatever speed it is that you normally drive (they know ;) )
I just drilled straight through the shield and flange on both sides and self-tappered the shield on.
Some people remove the shield altogether, but I figure that it helps keep the catalyst hot, so it will last a bit longer.
  • JivingDaddy
10 Feb 2013 07:55 #61854 by JivingDaddy
Mine is connected together with nuts and bolts. ?! Didn't fancy trying to drill them out and having the drill bit jumping off and damaging something, so a bit of lateral thinking. I'll wrap an exhaust bandage around it. Worth a try for 99p.
If it withstands the heat OK and removes the annoying noise, I may see if it helps with another annoying noise and try it on the missus to keep her quiet.
Talking of which, better go, she's got laryngitis and I don't want to miss a minute of it. :laugh:
  • GuardianAngel
10 Feb 2013 08:05 #61855 by GuardianAngel
Replied by GuardianAngel on topic Re: Special Tool?
JivingDaddy wrote: Talking of which, better go, she's got laryngitis and I don't want to miss a minute of it. :laugh:
:D they moan about "man flu" but they are just as bad.
  • JivingDaddy
10 Feb 2013 08:18 #61858 by JivingDaddy
Replied by JivingDaddy on topic Re: Special Tool?
I haven't spoken to my wife for three months. We haven't fallen out, I'm just not quick enough to interrupt!! :ohmy:
Time to create page: 0.105 seconds
