Special Tool?
- Motty
08 Feb 2013 19:07 #61513
by Motty
My 54 plate has the same rusty exhaust (no holes yet) and cat rattle. I had better start saving :blush:
Replied by Motty on topic Special Tool?
JivingDaddy wrote: Kwik-Fit quoted 495 to change the whole system. Ouch. :S
- JivingDaddy
08 Feb 2013 19:36 #61519
by JivingDaddy
Replied by JivingDaddy on topic Special Tool?
Hi Motty,
I've decided that the CO can put up with it until the weather improves. At least the new exhaust won't have to immediately suffer road grit and salt.
- adamatdraycott
08 Feb 2013 20:48 #61566
by adamatdraycott
Check the small heat shield slightly further along the exhaust pipe. These are fastened on with clips similar to jubilee clips at the factory... And rust through and allow the shield to vibrate badly.
I replaced mine with stainless jubilees and have no rattles at all now
Replied by adamatdraycott on topic Special Tool?
- barnes
08 Feb 2013 21:01 #61574
by barnes
Replied by barnes on topic Special Tool?
You can get a full system for £140 quid kwik fit are a rip off
- wanderinstar
08 Feb 2013 23:12 #61624
by wanderinstar
Replied by wanderinstar on topic Special Tool?
Regarding getting the plugs out use a bit if heat from a blow lamp. It comes out easy peaty then . Don't forget to take filler plug out first, cos it is no good draining down only to find you can't get filler plug out!!!
- JivingDaddy
09 Feb 2013 08:56 #61638
by JivingDaddy
Thanks to all for their feedback re both the filler plugs and exhaust.
Re the plugs, I'll get a 1/2 to 3/8 reducer (and spare gaskets ready for when I put them back).
Re the exhaust, it is definitely the heat shield. Held together with nuts and bolts. They've stretched and I can rattle the shield by hand. May just sort that for now and fit a complete exhaust replacement when the weather improves.
Time to create page: 0.111 seconds
