relaying brake lights to a switch
22 Jan 2013 21:33 - 22 Jan 2013 23:08 #59189 by gilburton
It's quite tight under there but you need to remove the plug on to the switch. It has a spring plastic piece on the side which you press in to release and wiggle/pull the plug off. It gives you a little bit more to get access.
You now need to identify the "live" wire. It should be live even with the ign. off. Then it's simply a case of cutting it and extending the wiring through an on/off switch.
I added cruise control to mine and had to wire a cut off to the brake switch.
Just to add I don't suppose it really matters whether you cut the live wire or the earth wire.
Either way you will interrupt the circuit.
I started off high and worked my way down ever since :-)
Last edit: 22 Jan 2013 23:08 by gilburton.
24 Jan 2013 04:57 #59384 by Halford
I quite fancy doing the opposite
.... wiring the brake lights to a switch so that they'll come on when I press the switch
........... is that possible ??? :huh:
I could then have some perverse fun with taxi drivers and bairns occasionally tailgating me :evil:
  • darthloachie
  • Visitor
  • Visitor
24 Jan 2013 15:52 #59410 by darthloachie
Replied by darthloachie on topic relaying brake lights to a switch
Halford wrote: I quite fancy doing the opposite
much better would be a KC daylighter with a 150w bulb mounted on the rear door aimed at their eyes :evil:
  • VAXXi
  • Visitor
  • Visitor
24 Jan 2013 18:18 #59427 by VAXXi
Replied by VAXXi on topic Re: relaying brake lights to a switch
Halford wrote: wiring the brake lights to a switch so that they'll come on when I press the switch
Why bother? just tap the brake lightly, it's enough. The method Darthloachie suggests below is even better, nothing like seeing two "headlights" facing you in your lane :-D
  • littlegreenjimny
  • Visitor
  • Visitor
25 Jan 2013 13:44 #59518 by littlegreenjimny
Replied by littlegreenjimny on topic Re: relaying brake lights to a switch
Get an old blanket slam it hanging out of the boot door so it hangs over the light
Or use some sort of tape
Time to create page: 0.169 seconds
