relaying brake lights to a switch
- hjb_1990
21 Jan 2013 22:33 #59041
by hjb_1990
relaying brake lights to a switch was created by hjb_1990
Is it a major job to relay the brake lights onto a switch as when i go lamping at night in my Jimny and hit the brakes it illuminates the field! Is there a kit you can buy and/or what components do i need and its is do-able which limited electrical knowledge?
- Skinhead
21 Jan 2013 22:53 #59044
by Skinhead
Replied by Skinhead on topic relaying brake lights to a switch
Use the handbreak :laugh:
- Dave cc
21 Jan 2013 22:53 #59045
by Dave cc
Replied by Dave cc on topic relaying brake lights to a switch
so you want to disable your brake lights ????
- supergaz
22 Jan 2013 07:43 #59073
by supergaz
Replied by supergaz on topic relaying brake lights to a switch
Simple, just find the brake light switch on the brake pedal, then break into the wire and fit a on/off switch. But remember to put it back on for the road.
- Dave cc
22 Jan 2013 07:53 - 22 Jan 2013 07:54 #59074
by Dave cc
As supergaz says easy just put a switch into the feed from the break pedal switch if you used a switch with double contacts you get then bring on a warning light inside the car to show they were disabled
Last edit: 22 Jan 2013 07:54 by Dave cc.
- hjb_1990
22 Jan 2013 12:08 #59088
by hjb_1990
Replied by hjb_1990 on topic relaying brake lights to a switch
Yes basically i want a switch on the dash where i can disable the break lights for shooting at night but simply switch them back on for when i'm back on the road. Thanks for the advice ill have a look this afternoon how accessible the wiring is around the break pedal.
Time to create page: 0.088 seconds
