6 hours broken down should i be worried ?
22 Jan 2013 09:55 #59081 by mlines
I know its of no use to you to know this but....
Whilst the Jimny engines (both G13 and M13) will give a long and reliable life, they will only do this if they have regular oil changes with a quality oil. Don't let the oil get at all gunky as the oil ways will block and the engine will die. Regular oil changes are a worthwhile investment for Jimnys.
  • ohgoon2006
22 Jan 2013 10:22 #59082 by ohgoon2006
Replied by ohgoon2006 on topic 6 hours broken down should i be worried ?
Looks like block gauze in sump caused the problem bit of bearings in crank case just not sure if putting new ones in will fix problem or new engine needed ?
  • Dave cc
23 Jan 2013 17:14 #59300 by Dave cc
Replied by Dave cc on topic 6 hours broken down should i be worried ?
How you getting on with geting the car fixed new engine or can it be repaired
  • GuardianAngel
23 Jan 2013 17:51 #59305 by GuardianAngel
Replied by GuardianAngel on topic Re: 6 hours broken down should i be worried ?
mlines wrote: I know its of no use to you to know this but....
When you say regular, do you mean more regular than the official schedule?
23 Jan 2013 18:09 #59308 by mlines
No, not more regular, just adhere to the schedule.
The problem is that Suzuki 4x4 owners (Jimny, SJ etc.) tend to like to do things cheaply ;) and this is one area not to scrimp and save on.
The following user(s) said Thank You: GuardianAngel
23 Jan 2013 22:47 #59372 by kirkynut
ohgoon2006 wrote: Looks like block gauze in sump caused the problem bit of bearings in crank case just not sure if putting new ones in will fix problem or new engine needed ?
Ah, perhaps it is kaput then cos the bit of bearing has to have come from somewhere which means it ain't where it ought to be, so something is badly wrong and won't last long! Also, what other bits of bearing are in there and what damage have they done.
Still give a try but I am beginning to think it's a dead cert kaput engine! My optimism has wained!
Time to create page: 0.200 seconds
