4wd problem
- MWells
Jacqui wrote: Glad to hear you got your 4wd problem sorted Lynnskatz!
I love my 02 jimny which I got in September. Its had a lot of previous owners but was a good price so we decided to go for it anyway. Had a bit of a nightmare time sorting out all the issues and general lack of care from previous owners. Thought it was just about under control and only a cosmetic bonnet issue after a fire to sort out!! when today of all days, in South Wales, we have now discovered that the 4wd is not working...arrrrghhh! Already has flexible hoses so not a corrosion issue. If anyone has any suggestions they would be gratefully appreciated. Hubby still got to work in it this morning though so still impressed.
Probably a leak some where in the system. The hubs can be made to lock manualy followings this that way you should have 4 wheel drive unless something more untoward is wrong with the drive line somewhere. I and a few others have done it with no real problems, parts in the front axle will get slightly more wear long term but i know i would rather have working 4wd than not working.
HTH Mark
- badboy-jimny
- Jacqui
- Jacqui
The controller box is just a small black box situated up under the dash on the drivers side and has a yellow plug going to it. I hope that this will be of some assistance to others that may have a similar problem.
- Laminak
I have a problem too with my 4WD system :sick:
I change all my caoutchouc vacuum hoses by silicon hoses.
One of pipe was blocked. I freed it (is it correct :whistle: ).
But I have no "clack clack" from my hub.
Do you think that I have leak in my vacuum pipes???
