4wd problem
- Lynnskatz
14 Jan 2013 19:38 #58044
by Lynnskatz
4wd problem was created by Lynnskatz
Hi first of all i better introduce myself, im Lynn im from tyne & Wear and ive just bought my Jimny
unfortunetly the 4x4 isnt working, had it to my local garage and the front vacuum pipe has corroded and snapped off near the front drivers side hub.
Does anyone know somewhere cheaper than the main dealers for a replacement vacuum pipe?
Thanks in advance
Thanks in advance
- Sponnie
14 Jan 2013 19:57 #58048
by Sponnie
Replied by Sponnie on topic 4wd problem
If the corrosion is in the middle'ish of the pipe, you could cut it out and slip over the pipe some synthetic pipe to connect them again.
The previous owner has done this on all my vacuum pipes.
Hope this helps. New pipes are probably quite expensive from Suzuki, perhaps Martin can provide you with some.
- Lynnskatz
14 Jan 2013 20:03 - 14 Jan 2013 20:06 #58050
by Lynnskatz
Replied by Lynnskatz on topic 4wd problem
Hi thanks for the reply but unfortunetly its on the end of the flexi at the hub plus the rest of the pipe doesnt look too good either
how do i get in touch with Martin? thanks
Last edit: 14 Jan 2013 20:06 by Lynnskatz.
- Sponnie
14 Jan 2013 20:18 #58053
by Sponnie
Thats a bugger.
Martin is mlines, so you can send him a PM
15 Jan 2013 13:47 #58148
by Halford
Replied by Halford on topic 4wd problem
Hi Lynn and welcome along.
there's a few of us in Tyne & Wear, where abouts are you ?
I'm in South Shields and can recommend a a trustworthy, non-rip-off garage in Shields if that's any good
he knows about Jimny's too
- Thank you received: 115
15 Jan 2013 14:06 #58150
by maverick
Jalapeño, IISY?
Replied by maverick on topic 4wd problem
maybe a better option would be (like me) get rid of the vacuum system altogether and fit Free Wheeling Hubs.
Then YOU control when the front shafts are turning and not some stupid vacuum system!
Jalapeño, IISY?
Time to create page: 0.172 seconds
