M16 straight swap?
- JonnyJimny
27 Dec 2012 16:10 #56340
by JonnyJimny
M16 straight swap? was created by JonnyJimny
I'm looking for better acceleration from my jimny to make it more usable for camping etc. I don't want to mess about with the M13 and I'd like something that looks all original and factory looking. Is an M16 pretty much a straight swap or is there a lot more to it than meets the eye?
Many thanks, Jon
Many thanks, Jon
- JonnyJimny
27 Dec 2012 17:50 #56347
by JonnyJimny
Replied by JonnyJimny on topic M16 straight swap?
Excellent news thanks. Any particular engine to look out for? How do they take to bing longitudinally mounted? Sump etc?
Thanks for your help.
- Bigchridy
27 Dec 2012 19:05 #56353
by Bigchridy
Replied by Bigchridy on topic Re: M16 straight swap?
I can confirm it is a straight swap. You only need a bare m16a engine plus the relevant injectors. All manifolds etc are reused.
Chris
Sent from my Nexus 7 using Tapatalk 2
Chris
- Bigchridy
27 Dec 2012 19:11 #56354
by Bigchridy
The m16a blocks have the same castings as the m13a so the engine mounts just bolt straight to the block. You will have to discard the oil filter housing from the m16a as it will foul on the chassis. Buy a new oil filter thread for a jimny or reuse the old one so the oil filter can mount directly to the block. You will also have to swap the oil strainer and sump over as the m16a will foul the axle. And you will need the jimny rocker cover as the oil dip stick is in a different place.
Chris
Chris
- JonnyJimny
27 Dec 2012 23:35 #56380
by JonnyJimny
Thanks so much for all your help. I'm an ex-BMW & Audi tech so it'll be a doodle to do but I just wanted some clarification regarding compatible parts etc.
- JonnyJimny
27 Dec 2012 23:38 #56381
by JonnyJimny
So just to clarify, my jimny is a 2004 M13A, so a M16A is ok? I'm confused regarding the vvt
Time to create page: 0.204 seconds
