M16 straight swap?
  • Bigchridy
28 Dec 2012 18:14 #56435 by Bigchridy
Replied by Bigchridy on topic Re: M16 straight swap?
If your jimny is a m13a then you need an m16a. If it is a m13a vvt then you will need an m16a vvt. If its just a m16a you are after then look for an old Liana. I believe they fit the m16a vvt to newer grand vitaras.
From what I can gather you can't fit a vvt unit into a jimny that hasn't previously had one in it as the ecu won't be set up to run vvt.
Hope this helps
Chris
Sent from my Nexus 7 using Tapatalk 2
Time to create page: 0.178 seconds
