split charge system
- jayjay1990
26 Dec 2012 20:30 #56283
by jayjay1990
Replied by jayjay1990 on topic split charge system
So how is that wired in matey
- supergaz
26 Dec 2012 20:50 #56288
by supergaz
Replied by supergaz on topic split charge system
As usual, it detects battery voltage and once supply battery is high enough it engages. It is great as It does not require a trigger wire, which can affect some cars.
26 Dec 2012 21:11 #56290
by facade
Replied by facade on topic split charge system
I've been trying to mind my own business on this one :blink: but
Personally, I'd fit a split charge diode pack, they are about £70.
Disadvantages:
Disadvantages:
- They waste power the greater the charging current the greeter the voltage drop and the greater the power loss, won't stop the batteries charging up though.
- Cost
- the batteries don't connect together, so the winch battery can never drain the starter battery. However, trying to winch on a flat winch battery will short circuit the alternator, don't know what will happen, likely the alternator will self limit once the voltage collapses as it will run out of field current.
- Easy wiring, chop into alternator charge lead, take one diode to each battery, only needs 70A cable.
www.marcleleisure.co.uk/store/-c-366.htm...51850d26e4a6987172b6
- JerseyJimny
26 Dec 2012 21:34 #56297
by JerseyJimny
Replied by JerseyJimny on topic split charge system
27 Dec 2012 01:08 #56315
by facade
You can modify the alternator to sense the actual voltage at the starter battery, and overcome the diode voltage drop problem.
The cheapest solution is to join the battery positives with a great thick cable, then insert a battery isolator switch into the link. Turn it on when the engine is running to charge both batteries in parallel, and off to isolate the winch battery.
This has the advantage of being able to use the winch battery to jump start the car if you left the lights on overnight.
The disadvantage is forgetting to turn it off.
- jayjay1990
27 Dec 2012 08:00 #56318
by jayjay1990
I'm not searching for the cheapest solution as I've allready spent the money on a 250a split charge relay, 120amp altinato
All the cable and 1000cca deep cycle batterys
Really this is my perfect set up for maximum power to run two winches so would rather stick with this rather than buy mor
I'm entering punch challenges next year hence wanting all this power and fast charging
All I need is somwhere to trigger the relay I'm thinking about trying it of a ignition triggered 12v source IE stereo
Time to create page: 0.159 seconds
