split charge system
  • jayjay1990
24 Dec 2012 14:27 #56108 by jayjay1990
split charge system was created by jayjay1990
hi
im fitting a split charge relay soon for a second battery im aware of how they work and how to fit as ive done them before
my question is , ive read that i cant connect and load to the altinator bulb wire
how have people got round this ?
jay
24 Dec 2012 16:09 #56118 by facade
Replied by facade on topic split charge system
I suspect that most people simply parallel the batteries.
You could fit a 200A cut off switch and simply turn it on when the engine is running.
You can get a simple voltage sensing relay for a split charge, probably work better as it will drop out if you try to winch on a flat battery rather than set fire to the split charge wiring.
I've never thought using the ignition light to trigger a relay is a good idea.
  • jayjay1990
24 Dec 2012 21:27 #56146 by jayjay1990
Replied by jayjay1990 on topic split charge system
i want a split charge system had to many flat batterys when winching lol so not going down the parrelel route
i know they can be fitted as a mate had one fitted but he now has sold the jimny and he dosnt know as it was allready fitted
so please if anyone has a split charge relay fitted what is theres wired to
  • supergaz
24 Dec 2012 22:18 #56150 by supergaz
Replied by supergaz on topic split charge system
I used an intelligent voltage sensing relay.
  • jayjay1990
26 Dec 2012 20:10 #56281 by jayjay1990
supergaz wrote: I used an intelligent voltage sensing relay.
Could you please post a link please for the one you used to give me a brief idea on what it dose and how it fits
Cheers mate
  • supergaz
26 Dec 2012 20:14 #56282 by supergaz
I'll get you details when its light, i got it from my local auto electrical place. Wasn't that expensive either, its only 60 amp so not to much pulled through alternator
Time to create page: 0.154 seconds
