Clutch change, How long.
12 Dec 2012 20:37 #55408 by dirtydogz
Replied by dirtydogz on topic Clutch change, How long.
I do know if it's a G13BB engine you don't need to remove the transfer box so that save you about 45 mins.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • Smoggy
12 Dec 2012 20:52 #55410 by Smoggy
Replied by Smoggy on topic Clutch change, How long.
No its twin cam motor :(
  • vitara_mad
12 Dec 2012 20:59 #55412 by vitara_mad
Replied by vitara_mad on topic Clutch change, How long.
theres no need to remove transfer box on any jimny to change the clutch ive done g13bb & m13a
im sure we did not remove front prop or exhaust either
  • jimnydms
12 Dec 2012 22:22 #55418 by jimnydms
Replied by jimnydms on topic Clutch change, How long.
I have just done clutch on mine 1st jimny clutch I ve done of the floor but have a 4" lift. My clutch was slipping like mad but the plate it's self didn't look that bad as above I expected to see threads and rivets but looked ok.... Havn t drove it yet as only just finished my TG crawler box to go in this weekend so time will tell !
  • jimbob
14 Dec 2012 07:19 #55488 by jimbob
Replied by jimbob on topic Clutch change, How long.
Well to tell you all about fitting a clutch in a jimny is like making toast I say this because I fit gearboxes and clutches for a living I can do a jimny clutch box out and back in with in an hour and yes if you took it to a garage they would charge you by the hour or give you a fix price for the job if your paying more than, lets say £350 that's on the high side kk :-)
  • 247sniper
15 Dec 2012 11:50 #55565 by 247sniper
Replied by 247sniper on topic Clutch change, How long.
Bloody hell guys, 7-8 hours! :blink:
The BOOK time for changing clutch plate,cover and release bearing is only 2.70 hours. even doing the job on axle stands you can get the box out in an hour.
If they charge you any more then 4 hours i would query it or better still when you drop the car off at the garage just highlight the fact that you are aware of the book time only being 2.70 hours.
Steve.
Time to create page: 0.211 seconds
