Diff / Transfer / Gearbox Oil Change
06 Nov 2016 08:10 #174285
Replied by Riccy on topic Diff / Transfer / Gearbox Oil Change
M13A(non-VVT) Engine UK
Gearbox Oil 1.1 litres API GL-4 75W - 90
Transfer Gearbox Oil 0.8 litres API GL-4 75W - 90
Differential Oil (front) 1.1 litres API GL-5 80W - 90
Differential Oil (rear) 1.3 litres API GL-5 80W - 90
Check you can undo the filler plug before draining the oil out
- Young Pretender
06 Nov 2016 08:15 #174286
by Young Pretender
Replied by Young Pretender on topic Diff / Transfer / Gearbox Oil Change
Cheers mate
09 Nov 2016 19:16 #174439
by Bosanek
Replied by Bosanek on topic Diff / Transfer / Gearbox Oil Change
If you have the time, I recommend that you wait a few hours for each oil to drain.
By doing so, you will drain more old oil, which can be a significant amount.
My story:
I changed my front differential oil a month ago.
I removed the drain plug and let the old oil out. When the old oil stopped dripping, I plugged the drain valve. But just as I approached to pour new oil in, I realized I had something else more important to do. I came back to the garage in the afternoon to finish the job. But before I poured new oil, I decided to remove the drain plug one more time, just to see if any remaining old oil is there.
To my surprise, at least 200-300 ml of more old oil drained from the front diff!
My story:
The following user(s) said Thank You: Young Pretender
- Young Pretender
13 Nov 2016 14:27 - 13 Nov 2016 14:28 #174581
by Young Pretender
Ok so filler plug is proving to be a bit stubborn. Have soaked/sprayed with wd40 about a week ago and trying to use my ratchet (which seems like a good fit) and a ring spanner off the ratchet for leverage but it isn't moving. My torque wrench or my proper tool (for plug fitment) won't fit on the filler plug because the fuel tank is in the way.
Any suggestions or tips for me? Have sprayed again with wd40 but would really like this job done today and getting impatient
Riccy wrote: Check you can undo the filler plug before draining the oil out
Last edit: 13 Nov 2016 14:28 by Young Pretender.
- Thank you received: 705
13 Nov 2016 14:30 #174582
Replied by jackonlyjack on topic Diff / Transfer / Gearbox Oil Change
can you lock a good pair of mole grips on the outside edge
Jack
Jack
- Young Pretender
13 Nov 2016 14:34 - 13 Nov 2016 15:23 #174583
by Young Pretender
If I had a decent set of mole grips I could try!
Last edit: 13 Nov 2016 15:23 by Young Pretender.
Time to create page: 1.125 seconds
