Diff / Transfer / Gearbox Oil Change
- Thank you received: 705
13 Nov 2016 15:05 #174586
Replied by jackonlyjack on topic Diff / Transfer / Gearbox Oil Change
you could trying to apply pressure anti clockwise and tap head of ratchet with hammer
i used 1/2 meter of scaffolding tube once to get leverage
Jack
Jack
13 Nov 2016 15:19 #174587
Replied by Riccy on topic Diff / Transfer / Gearbox Oil Change
Bet your glad you checked the filler plug first!
the first time i changed mine it took a 2ft long bar to get it off. hadnt been off in approx 8 years.
- Young Pretender
13 Nov 2016 15:24 - 13 Nov 2016 15:26 #174588
by Young Pretender
Replied by Young Pretender on topic Diff / Transfer / Gearbox Oil Change
You're not wrong!
Thanks gents, got them both out now.. best work out I've had in a while
Last edit: 13 Nov 2016 15:26 by Young Pretender.
- jim
13 Nov 2016 16:33 #174590
by jim
Replied by jim on topic Diff / Transfer / Gearbox Oil Change
30-60 seconds with a heat gun makes undoing them very easy.
- TarkMalbot
03 Aug 2020 13:08 #226023
by TarkMalbot
Replied by TarkMalbot on topic Diff / Transfer / Gearbox Oil Change
So I was looking for GL-4 75W-90 and GL-5 80W-90 and come across the following product. Would this be suitable to use in both the boxes and the diffs??
COMMA - GEAR OIL SX75W-90 GL-5 SEMI SYNTHETIC ALSO 75W-90 80W-90 85W-90
Suitable for modern five and six speed gear boxes and differentials.
Suitable for applications where a 75W-90, 75W-85, 80W-90 or 85W-90 API GL-5, GL-4 oil is specified.
Performance profile: SAE 75W, SAE 75W-90, SAE 80W, SAE 80W-90, SAE 85W, SAE 85W-90, SAE 90
- Thank you received: 1927
03 Aug 2020 15:35 #226026
Replied by Lambert on topic Diff / Transfer / Gearbox Oil Change
I have had issues with the use of gl4/5 combination oils in the main gear box. The shift become heavy until I changed it to a pure gl4 which took it back to its normal rifle bolt action.
Time to create page: 1.913 seconds
