unsolvable vibration... sad..
  • Soymilkfc
22 Oct 2012 12:57 #51032 by Soymilkfc
unsolvable vibration... sad.. was created by Soymilkfc
hey guys, the vibration happens only when accelerating below 2k rpm at gear three and four (gear four is worse than gear three).. changed all the mounts checked all the shafts and joints.. all ok.. vibration still there.. from my local mechanics, he says it is engine harmonic.. so any suggestions will be appreciated. thank you guya!
22 Oct 2012 13:34 #51033 by facade
Jimnys are prone to this (They all do that Sir :lol: )
Mine does it too, in 2nd as well, right at the speed that you go turn into a junction and then try and accelerate back up to speed.(1700rpm on the clock is the worst)
Assuming you have checked for loose propshaft joints and nuts & bolts generally.
Diesel Jimnys have a big mass damper screwed to the nose of the rear differential, so my money is on the axle & trailing arm mounts having gone soft with age, allowing the axle& propshaft to vibrate, ( soft engine & transfer mounts will make this worse).
Possible solutions:
1) Fit the damper from a diesel jimny, should screw straight onto 2 holes above the flange.
2) Throw money at it, changing all the rubbers, starting with the ones at the rear axle (You will not believe how much these cost)
3) Don't let it pull at this speed.
4) Ignore it and power through it ASAP
I tend to go for 3&4 ;)
  • markyp2000
22 Oct 2012 17:57 #51047 by markyp2000
Replied by markyp2000 on topic unsolvable vibration... sad..
my jimny does the same but my other jimny dont do it
  • blakey2000
22 Oct 2012 21:18 #51066 by blakey2000
Replied by blakey2000 on topic unsolvable vibration... sad..
sounds more like the engine is going to stall. trying to accelerate a fairly underpowered engine under 2k revs in 3 and 4th gear I'm not surprised the thing shudders like hell. try changing down a gear.
sounds like your putting a lot of extra load on the engine by having low revs in a higher gear at a slower speed.
to me your mechanic is spot on to the problem.
  • markyp2000
22 Oct 2012 21:23 #51068 by markyp2000
so how come i have 2 jimnys one year apart and i drive them the same one drives fine and the other vibrates like mad explain that then please blakey
  • blakey2000
23 Oct 2012 05:29 #51069 by blakey2000
they will both be doing it just the other one must be in better nick in the driveline department. and engine mount condition probably has something to do with how noticeable it is also.
