bad vibration
- Paul4x4
19 Oct 2012 03:29 #50774
by Paul4x4
Replied by Paul4x4 on topic bad vibration
Yeah, it could be the middle prop too. I know a samurai that had weird vibrations too, and it turned out to be a super stiff joint in the middle prop.markyp2000 wrote: thanks martin didnt think of doing that should a check the gbox to tbox prop also or is it unlikly to be that one
- Thank you received: 115
19 Oct 2012 12:48 #50785
by maverick
Jalapeño, IISY?
Replied by maverick on topic bad vibration
Deffo UJ's ... I had same problem - foolishly, I tested the UJ's when all the props were fitted - seemed ok, but when I took each and every prop of the car, nearly all UJs were knackered, and even worse one of the prop Flanges was so worn it was affecting the UJ replacement, and i ended up getting another flange! ...
Martin sells UJ's i think?.
Jalapeño, IISY?
19 Oct 2012 15:28 #50791
Replied by mlines on topic bad vibration
Its most likely the rear prop one, if its the mini-prop one you can see both the G-box and T-box levers shaking violently (based on a memory of the effect on my SJ)
- markyp2000
19 Oct 2012 16:55 #50800
by markyp2000
Replied by markyp2000 on topic bad vibration
well checked all prop UJs and thay are all ok crank pully is ok to
the only thing i found that i might replace was the tbox mounts as thay seem very soft i say this cos as i was greasing uo the front prop slider the tbox moved back quite away but thay are intacked
- ZookFastback
19 Oct 2012 23:58 #50864
by ZookFastback
Replied by ZookFastback on topic bad vibration
Another possible cause of vibration is from the tailshafts. If they lose the little weights that are glued/welded to them to balance them, this can cause vibration. Check the shafts for a small square that indicates a weight has come off.
- markyp2000
20 Oct 2012 13:12 #50885
by markyp2000
yer thay are all there
Time to create page: 0.098 seconds
