bad vibration
  • markyp2000
18 Oct 2012 21:12 #50752 by markyp2000
bad vibration was created by markyp2000
my jimny as a bad vibration at 2000rpm in 2nd 3rd and 4th trough the hole chassis its that bad the interior mirror moves
iv checked all the mounts tbox gbox and engine
prop shafts
suspension bushes
any body had this before or no what it may be
18 Oct 2012 21:15 #50753 by j999pre
Replied by j999pre on topic bad vibration
Crank pulley?
Grey pick up Jimny
  • markyp2000
18 Oct 2012 21:20 #50755 by markyp2000
Replied by markyp2000 on topic bad vibration
mmmmm was thinking that but it dont do it when you just rev it its only when moving i spent over an hour checking every thing i can think of either with a pry bar and checking tightness of thing and it still there and its a single cam engine just if any body asks
18 Oct 2012 21:54 #50758 by mlines
Replied by mlines on topic bad vibration
Frozen/stiff Universal joint.
You have to undo the prop to test this. Undo it and check it can be moved smoothly in all directions.
  • markyp2000
18 Oct 2012 22:07 #50759 by markyp2000
thanks martin didnt think of doing that should a check the gbox to tbox prop also or is it unlikly to be that one
  • ZookFastback
18 Oct 2012 23:51 #50768 by ZookFastback
Replied by ZookFastback on topic bad vibration
My vibration was caused by Uni joints seizing. When I replaced the 5 uni's i put in ones with grease nipples and give them a pump now and then. Did this over 200,000 k's ago and they are still as good as new.
