Rocklobster Gear Layout
  • reaper
18 Oct 2012 20:01 #50741 by reaper
Replied by reaper on topic Rocklobster Gear Layout
panosd wrote: Attention , if your t-case stick, sticks durring changing position, 100% your sfifter flange is worn out and
needs replacement. A good t-case doesn't stick durring changes.
No hammer etc needed. Just a replacement of the flange and also have a look at the roller bearings.
Hope not mine is brand new
  • Smoggy
18 Oct 2012 20:13 #50746 by Smoggy
Replied by Smoggy on topic Rocklobster Gear Layout
Oops so is mine :cheer:
  • Rockwatt
19 Oct 2012 06:00 #50777 by Rockwatt
Replied by Rockwatt on topic Rocklobster Gear Layout
yes the shifter "sheet" must be in good condition but there is also things internally that also need to be good ! The cases sometimes suffer from elongation in the shifter shaft slides ! This is often overlooked by some builders.
the clunk that you get when going into 4 low is due to a few things . One being the bigger step in ratios from high to low with no syncro's. Another is the way the lever is bent to fit
In the jimmy effectively shortens it and reduces leverage. (I prefer the cut a new hole and cover the old one method)
  • reaper
19 Oct 2012 19:18 #50835 by reaper
