Rocklobster Gear Layout
- Smoggy
17 Oct 2012 18:59 #50611
by Smoggy
Rocklobster Gear Layout was created by Smoggy
I am having difficulty working out what should be happening with my driven wheels. The lobster appears to have a J style layout. The front prop is connected to an SJ axle with fixed (not manual locking) hubs via an ARB locking diff. The rear prop drives the rear Jimny axle via another ARB locking diff.
What should be happening under each setting and how am I best to test everything out to make sure it is all working correctly.
Many Thanks.
Many Thanks.
- reaper
17 Oct 2012 19:41 - 17 Oct 2012 19:48 #50618
by reaper
Replied by reaper on topic Rocklobster Gear Layout
.....4l
2h...n
......4h
Is the patten so if you disconnect the output flanges you will get drive in 4h and 4l to both flanges and in 2h just to the rear one
2h...n
......4h
Last edit: 17 Oct 2012 19:48 by reaper.
- Smoggy
17 Oct 2012 20:02 #50628
by Smoggy
Replied by Smoggy on topic Rocklobster Gear Layout
Thanks Dale. When you select 4L do you notice that it is a little more clunky than when you select the other configurations.
- reaper
17 Oct 2012 20:04 #50630
by reaper
Carry a hammer
The gear selection is alot harder than the stock box , you do have to give it a good tug to get it in 4l and yea makes quite a clunk
- Smoggy
17 Oct 2012 20:15 #50636
by Smoggy
Thank god for that I thought I had broke it.
17 Oct 2012 20:19 - 17 Oct 2012 20:36 #50638
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Rocklobster Gear Layout
2002 JLX Soft Top
Last edit: 17 Oct 2012 20:36 by dirtydogz.
Time to create page: 0.472 seconds
