Remote locking fob
  • Jamie
18 Sep 2010 04:39 #4711 by Jamie
Remote locking fob was created by Jamie
Has anyone changed batteries in thiers??
Mine doesnt work and when i opened it up i couldnt
see a battery.......Any ides???
Jamie
  • darthloachie
18 Sep 2010 14:17 #4714 by darthloachie
Replied by darthloachie on topic Re:Remote locking fob
I dream about having remote central locking :whistle:
Have you tried holding it against your head when you press it - it increases the range
18 Sep 2010 14:39 #4715 by facade
Replied by facade on topic Re:Remote locking fob
You have a fob???
Never seen one. However there is a section in the manual, may be the battery dead, or the remote needs synchronising with the car. It is supposed to be part of the key.
REPLACEMENT OF TRANSMITTER BATTERY
If transmitter becomes unreliable, replace transmitter battery as
follows.
1) Remove screw (1) and transmitter cover (2).
2) Remove transmitter (3) from transmitter holder (4).
3) Put edge of coin or flat blade screwdriver in slot of transmitter
(3) and by pry it open.
4) Replace the battery (lithium disc-type CR1616 or equivalent
battery) so its + terminal faces “+” mark on transmitter.
5) Fit together transmitter (3) and install it into transmitter
holder (4).
6) Install transmitter cover (2) and screw (1).
7) Make sure the door locks can be operated with transmitter.
CODE REGISTRATION PROCEDURE
If transmitter or door lock controller replace new one, register key
code as follows.
1) Confirm that the vehicle is the following conditions.
• All doors are closed.
• Ignition key is out of ignition switch.
• Driver side door is unlocked.
2) Disconnect negative (-) cable from battery.
3) After 30 seconds, perform the following procedure within 60
seconds.
a) Connect negative (-) cable to battery.
b) Operate driver side door knob switch from lock to unlock.
c) Push “LOCK” button on transmitter and confirm that are
operated from lock to unlock.
d) Push driver side door knob switch to lock position.
e) Push “LOCK” button on transmitter twice and confirm that
all doors are operated from unlock to lock. With this, code
registration is completed.
  • Jamie
18 Sep 2010 17:08 #4721 by Jamie
Replied by Jamie on topic Re:Remote locking fob
I forgot about the manual.....Dope!!!!!
Thats great thanks for digging that out for me
i didn't see a slot for a coin when i opened it,
Probably wasn't looking hard enough!!!
Thanks again
Jamie
19 Sep 2010 22:39 #4742 by kirkynut
Replied by kirkynut on topic Re:Remote locking fob
I don't have a remote locking fob either, which is probably a good idea as I'd only drop it in a puddle if I did!
Time to create page: 0.189 seconds
