swift gti engine
- nate78
13 Oct 2012 08:25 #50138
by nate78
Replied by nate78 on topic swift gti engine
i will have a search, thanks
- nate78
13 Oct 2012 09:50 #50142
by nate78
ive read a few threads on this engine but it seems that its not that straight forward, if you could shed some light on the swift gti g13b engine i would appriciate it, thanks
- TomDK
13 Oct 2012 09:55 #50143
by TomDK
Replied by TomDK on topic swift gti engine
Why not read the answer paul4x4 posted earlier?
- nate78
13 Oct 2012 12:08 #50151
by nate78
i have and i asked the question about the 1.6 engine, hopefully he will be along shortly, i know i keep banging on about the swift engine, but from what read the internals in that engine are stronger than the standard jimny engine,
- Paul4x4
13 Oct 2012 12:26 #50157
by Paul4x4
And what comes to GTI engine, there's a lot of things that are better compared to the Jimny engine, and the internals are said to be the strongest that Suzuki have ever manufactured. The GTI bolts right on to the Jimny transmission, but that's about it. You need to change all the electrics involved, and that's a bit of work hooking it all up! Basically you can swap any engine in with almost the same amount of work at the point you start messing with the engine management electrics, so the easiest swaps are those that still use the Jimny's own cylinder head and electrics, or another suzuki engine that would run on the same ecu(is there any? I don't know).
Replied by Paul4x4 on topic swift gti engine
You just need an adapter to fit the 1600cc block to the Jimny transmission, and might need to swap in another starter that fits the adapter plate. I haven't done this myself(I've been thinking about it a lot though), but from what I have read, all the needed parts are available so it doesn't require any fabricating, so it's basically bolt on after you have gathered all the parts.nate78 wrote: i have and i asked the question about the 1.6 engine, hopefully he will be along shortly, i know i keep banging on about the swift engine, but from what read the internals in that engine are stronger than the standard jimny engine,
- nate78
13 Oct 2012 14:52 - 13 Oct 2012 14:57 #50163
by nate78
1.6 16v is the way to go then, so best to use the jimny head, transmission with the vitara block, the 'skinny starter' id better start searching for parts, thanks
what year vitaras have the g16b engine?
Last edit: 13 Oct 2012 14:57 by nate78. Reason: .
Time to create page: 0.164 seconds
