Now it wont start
  • markyp2000
12 Oct 2012 19:22 #50082 by markyp2000
Replied by markyp2000 on topic Now it wont start
what engine is it single or twin cam when you removed the vacuum pipe for the hubs did you block the manifold outlets up
  • Smoggy
12 Oct 2012 19:32 #50085 by Smoggy
Replied by Smoggy on topic Now it wont start
Twin cam, no i didnt block anything yet Mark.
  • markyp2000
12 Oct 2012 19:44 #50087 by markyp2000
it try that first as your creating an air leak after the throttle butterfly so your drawing in more than it mesures as it goes through the butterfly
  • Smoggy
12 Oct 2012 19:45 #50088 by Smoggy
Cheers Marky.
12 Oct 2012 21:03 #50096 by facade
Replied by facade on topic Now it wont start
Just got home to see the thread. Marky is right, there is a vacuum port on the outside of the inlet manifold that has a rubber pipe pushed on that used to go to the vacuum valves. This needs capping off, just cut 1" of pipe, and put a chopped off nail in one end then push over the spigot.
The following user(s) said Thank You: Smoggy
  • Smoggy
12 Oct 2012 21:09 - 12 Oct 2012 21:24 #50098 by Smoggy
Thankyou Facade, between yourself, Marky, Kirky, Paul 4x4 and a few others you provide a wealth of information and I for one am eternally grateful for the help you guys provide.
Last edit: 12 Oct 2012 21:24 by Smoggy.
