Now it wont start
  • phillet
30 Aug 2012 08:43 #47103 by phillet
New member with a new jimny. was created by phillet
I have previously been a Land Rover owner, having started with a 1960 S2 followed by a 1989 Land Rover Discovery, however after the clutch on the Discovery died and it spectacularly failed it’s MOT I was left without a 4x4 for three years.
Once getting a new job, I decided to treat myself to another 4x4, I have had several friends who have had Suzuki Jimny’s before and all of them have loved them, and they have proved to be a relatively cheap 4x4 to own and run, so I decided to go for a Jimny. Originally I was looking at a 3 year old (ish) Jimny, but it seemed to make more finical sense to buy a new one, so that is what I have done.
Here she is as I bought her;
[img
And a couple of her first trips out and about.
[img
[img
First off all I added an off road scratch on her, within two weeks off having bought her. (It looks worse - or better dependent on your opinion - in the flesh)
[img
I then put some all terrain tyres on her. (Competus A/T 4x4 - 205 / 70 R15)
[img
Followed by a new bonnet mounted number plate after having lost two number plates whilst laning in the past.
[img
And here she is in her current form, much cleaner than normal
[img
My CB setup
[img
I also plan to get underneath the car with some waxoil at some point over the winter, and pretty much coat everything I can in it to try and prevent any rust. And also think about some under body protection and a lift, but I need to watch this with the car being under warranty.
Phil
  • Smoggy
12 Oct 2012 18:37 #50071 by Smoggy
Replied by Smoggy on topic Now it wont start
It started fine before I started the mods, now it takes an eternity to fire but once its running its ok. Some things I have done that could have caused the problems:
Had the exhaust off then back on again along with the lambda sensor.
Removed the vacuum hubs (along with the vacuum bottle in the wing void) and fitted SJ fixed items all vacuum pipes have been left open and not plugged.
Moved the fusebox which is still loose in engine bay, some of the wires going into the box have corroded and maybe loose too not had chance to check which circuits yet.
I know its a big ask given the above info but any ideas on why its taking ages to fire.
Thanks.
  • markyp2000
12 Oct 2012 18:44 #50073 by markyp2000
Replied by markyp2000 on topic Now it wont start
coolent temp sensor fuel presure regulator valve has a vacuum pipe on it fuel pump ie low pressure what size pipe did you replace the fuel pipe with was it a similor size
  • Smoggy
12 Oct 2012 19:03 #50077 by Smoggy
Yeah all the fuel lines were similar size to original, also when it does start tickover is fine and when its revved there seems plenty of response there with no delay in the power delivery.
  • markyp2000
12 Oct 2012 19:09 #50080 by markyp2000
fuel could be running out of the rail back to the tank past the fuel regulator
  • Smoggy
12 Oct 2012 19:19 #50081 by Smoggy
It was working okay before I modded it and I havent touched the fuel rail at all, except for making the fuel pipe connections to it. Could it be something to do with a vacuum alteration due to removal of the jimny vac hubs and the vac reservoir in the wing void.
Time to create page: 0.263 seconds
