Front axle alignment
12 Oct 2012 10:52 #50060 by saxj
Front axle alignment was created by saxj
My Jimny was in an accident which caused the panhard rod to get bent. Now even after the rod has been straightened, The axle is still out of alignment.
How do I measure to make sure that the axle has been aligned correctly?
  • Paul4x4
12 Oct 2012 11:49 #50061 by Paul4x4
Replied by Paul4x4 on topic Front axle alignment
Measure the distance between wheel rim and chassis rail. Should be equal both sides.
  • markyp2000
12 Oct 2012 18:54 - 12 Oct 2012 18:55 #50075 by markyp2000
Replied by markyp2000 on topic Front axle alignment
fit a new or used panard rod as the bent on that has been strightened may not be 100% true
or the mounting point on the axle/chassis may be bent out or alignment
Last edit: 12 Oct 2012 18:55 by markyp2000.
  • Smoggy
12 Oct 2012 19:06 #50078 by Smoggy
Replied by Smoggy on topic Front axle alignment
I think I mahy have an undamaged panhard rod you can have saxj, whereabouts are you. I can send it to you for the price of the postage if your not close.
16 Oct 2012 06:21 #50395 by saxj
Replied by saxj on topic Front axle alignment
Paul4x4 wrote: Measure the distance between wheel rim and chassis rail. Should be equal both sides.
I forgot to say that its lifted. What should the difference be with a 40mm spacer lift?
16 Oct 2012 06:22 #50396 by saxj
Smoggy wrote: I think I mahy have an undamaged panhard rod you can have saxj, whereabouts are you. I can send it to you for the price of the postage if your not close.
Thanks, but I think the postage may be a bit excessive, I'm in South Africa.
Time to create page: 0.162 seconds
