Help needed from a new we
- Rob2933
09 Oct 2012 06:03 #49793
by Rob2933
Replied by Rob2933 on topic Help needed from a new we
Hi the car has been standing in garage for 3 years been move regular for mot and a quick run here and there its always been ok but got the problem when it was coming home from last test the cam censor was change the clutch is new ans brakes have been done these no binding or slipping of clutch the cat was a bit rusty but to be bonest not that bad after reading your comments I took the exhaust sensor out and looking at it it could be the problem it's a bit corroded and looks like it has melted abit so replacement will be put in today il let you no how it goes thank you to every body that taken time to help in sorting this problem out hopefully this sensor will cure it thanks again bob
- Tadpole
09 Oct 2012 08:43 #49800
by Tadpole
Replied by Tadpole on topic Help needed from a new we
Let's hope it's this for an easy fix, thanks for the up-date ..
09 Oct 2012 10:52 #49806
by kirkynut
Replied by kirkynut on topic Help needed from a new we
As Tadpole says, I hope it is the lambda for you! Looking forward to hearing the result, I've been following this thread but not had any different ideas. If this doesn't work I'd be looking at Marks last suggestions regarding coolant temp sender etc, the plugs will be blackened if that is the case or at least darker. So whipping one out my help diagnose that. Hope It's the lambda though to solve it now!
- Rob2933
09 Oct 2012 11:26 #49808
by Rob2933
Well here goes change the sensor and the little jimnys back in action!!! Now flying up the hills lol so a big thank you to all that helped without it I would have been in the s/////t
Thanks again guys bob
09 Oct 2012 12:19 #49813
by kirkynut
Awesome, glad about that! Something for us all to bear in mind if we have the same symptoms.cheers
Time to create page: 0.162 seconds
