Help needed from a new we
  • Rob2933
04 Oct 2012 18:07 - 04 Oct 2012 18:10 #49470 by Rob2933
Help needed from a new we was created by Rob2933
Thanks in advance for any help given
Here goes got a jimny 2000reg with 60000 on clock the problem I have is it seems that when you put your foot down to go it don't but if you do it slowly it will pick up and go also power less going up small inclines it ticks over fine and if you rev it up into the red it misses bad no engine light shows but is working any help would be deeply appreciated thank you bob ps forgot to menshion it's had a new cam sensor a year ago thanks
Last edit: 04 Oct 2012 18:10 by Rob2933. Reason: Added new info
04 Oct 2012 19:27 - 04 Oct 2012 19:27 #49495 by dirtydogz
Replied by dirtydogz on topic Help needed from a new we
It might be the clutch slipping so you might need to adjusting it .
And the red line is there so you don't over rev the engine.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 04 Oct 2012 19:27 by dirtydogz.
  • Rob2933
04 Oct 2012 19:31 #49496 by Rob2933
Replied by Rob2933 on topic Help needed from a new we
Clutch is new defo not that it's not over reving it's just got no power with your foot down thank you anyway bob
04 Oct 2012 19:39 #49503 by facade
Replied by facade on topic Help needed from a new we
The usual suspect is a blocked up catalyst.
A new one is quite expensive though.
The following user(s) said Thank You: Rob2933
  • markyp2000
04 Oct 2012 20:49 #49513 by markyp2000
Replied by markyp2000 on topic Help needed from a new we
if you rev it in to the red and its missing id say your hitting the rev limiter
  • Rob2933
04 Oct 2012 22:03 - 04 Oct 2012 22:06 #49519 by Rob2933
Just been on fleabay there's a new cat for125 will try that thanks bob
Last edit: 04 Oct 2012 22:06 by Rob2933. Reason: Spelling
Time to create page: 1.205 seconds
