Engine knocking
  • renard38
02 Oct 2012 17:08 #49349 by renard38
Replied by renard38 on topic Engine knocking
with my old jimny ( the same motor ) i had the same noise and it was the Exhaust manifold gasket:
www.tegiwaimports.com/tegiwa-2-2-25-2-5-...ut-gasket-ring-1445/
when the motor run, put your hand near the Exhaust manifold gasket:, and if you feel a breath on your hand, it's this problem ( i hope you understand my bad english ;) )
  • markyp2000
02 Oct 2012 17:49 #49353 by markyp2000
Replied by markyp2000 on topic Engine knocking
it would take less time to do the bearings than to change the engine
02 Oct 2012 17:51 #49354 by j999pre
Replied by j999pre on topic Engine knocking
markyp2000 wrote: it would take less time to do the bearings than to change the engine
Worth a punt if the crank is ok and the rest of the engine is good
Grey pick up Jimny
  • markyp2000
02 Oct 2012 18:07 #49355 by markyp2000
exactly it dont cost nothing to look
  • craigwoody69
02 Oct 2012 18:18 #49356 by craigwoody69
Replied by craigwoody69 on topic Engine knocking
thank you people, i havent had a proper look over it yet, il check the exhaust manifold tomorrow.
how difficult would it be changing the thrust bearing or whats a way of telling its that?
what shall i look for under the cam cover j999pre?
I've tried looking what i need to swap over on the engines but havent found anything. Is it challenging swapping things over to make it work or simple?
if you would be so kind to point me in the right direction or explain what needs to be done would be much appreciated.
this is my first jeep for offroading, its abit different to my mx5 drifter ha
02 Oct 2012 20:00 #49358 by mlines
Replied by mlines on topic Engine knocking
The problem you would have is that you have a G13BB engine and a 2001 Hard Top is likely to have an M13AA engine. This means you have to take the engine and gearbox as well and also would have to play around in a major way with the wiring loom and ECU etc.
It would be easiest to find another G13BB engine and then do the swap.
Time to create page: 0.099 seconds
