Engine knocking
- craigwoody69
14 years 1 month ago - 14 years 1 month ago #49270
by craigwoody69
Engine knocking was created by craigwoody69
hello people,
I've just bought a 2000 plate soft top jimny for £250, it has a horrible knocking coming from the bottom of the engine. I'm just wondering if it'll be easier fixing it or just swapping the engine here's a video of the horrible noise.
Last edit: 14 years 1 month ago by craigwoody69.
- markyp2000
14 years 1 month ago #49272
by markyp2000
Replied by markyp2000 on topic Engine knocking
if it was me id strip it and see whats wrong first id check the tappets if all ok remove the sump and check the bigend bearings/conrod bearings for as little as say £80 you could have a good engine if the crank is ok
- craigwoody69
14 years 1 month ago #49337
by craigwoody69
Replied by craigwoody69 on topic Engine knocking
i dont really have the time or space to do that yet. i can get a replacement engine for it for cheap but its out of a 2001 hard top model.
But will that be a straight swap?? I've read a few threads where it says there different but i dont know this is my first suzuki
- craigwoody69
14 years 1 month ago #49342
by craigwoody69
someone on another forum suggested it could be the thrust bearing anyone else think it could be that?
14 years 1 month ago #49343
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Engine knocking
I'd do the cheap engine swap. You may have to swap sumps, camshaft and oil pump though to go from hard to soft top.
Have you had the cam cover off and had a look?
Grey pick up Jimny
- ne-crock
14 years 1 month ago #49344
by ne-crock
Replied by ne-crock on topic Engine knocking
I'm not sure on the bearing front,
but the hardtop engine from a 2001 would not be a straight swap i'm affraid to say, its a m13a engine where as us soft top owners have a g13b engine
Time to create page: 0.104 seconds
