Malfunction indicator light vvt engine
  • markyp2000
14 years 1 month ago #49155 by markyp2000
Replied by markyp2000 on topic Malfunction indicator light vvt engine
trust me it can be any thing if it related to the emissions it could be a miss fire a coil pack a spark plug/lead o2/lambda/oxygen sensor coolent sensor idol control valve trottle position sensor egr valve (exhaust gas resurculate valve) injector the list goes on
  • treasurer
14 years 1 month ago #49156 by treasurer
Replied by treasurer on topic Malfunction indicator light vvt engine
thanks for your help
well it seems to be driving ok
so what is your advice ?
get it checked out or just take the battery off and see if it resets?
14 years 1 month ago #49157 by facade
Usually you have to reset one touch windows if the battery is off for a while. On the old Corsa you simply wound them up full, and hold the switch on up for 30 seconds. Maybe a jimny doesn't have them, my X reg likely doesn't, or I haven't found how to reset them yet :)
I'd read the codes myself, or you could pay someone more than a code reader to do it for you.
I know that Jimnys go through more oxygen sensors than they do crank sensors than they do cam sensors than they do coil packs, and there is no miss fire, so blind guessing, oxygen sensor.
Could be catalyst, which sometimes shows as oxygen sensor fault on the downstream sensor.
Best to read the codes rather than throw money at it blind though.
  • treasurer
14 years 1 month ago #49158 by treasurer
ok thanks
where can i get a car code reader from?
14 years 1 month ago - 14 years 1 month ago #49159 by facade
I'd drive it with the light on and get a code reader. Disconnecting the battery can cause more problems.
Treasurer, if you filled in your location, someone local to you might have a code reader and can check for you. I would if you lived near Walsall.
Plenty of £20 ones on eBay you want one that does OBD2 and says Suzuki in the supported cars list.
Last edit: 14 years 1 month ago by facade.
  • treasurer
14 years 1 month ago #49160 by treasurer
thanks Facade
i will buy one off ebay and see whats wrong
never had this problem with points and carburators lol
Time to create page: 0.095 seconds
