Malfunction indicator light vvt engine
- treasurer
30 Sep 2012 13:08 #49140
by treasurer
Malfunction indicator light vvt engine was created by treasurer
Hi
The orange engine light has just come on the dash of my vvt jimny
The owneres manual says it is a problem with the emission control system and take to the suzuki dealer.
The Car seems to drive ok and accelerate fine
so has anybody had this fault or know the cure
thanks
ian
thanks
ian
30 Sep 2012 14:00 #49144
by facade
Replied by facade on topic Malfunction indicator light vvt engine
Plug a £20 code reader into the diagnostic plug above the drivers left knee.
Read the fault code, and clear it.
If it comes back, do it again, but this time fix the indicated problem
Most likely oxygen sensor #1 the one before the catalyst.
As an alternative, disconnect the battery for 20 minutes, this should clear the codes. Do NOT do this if you don;t know the radio code, or how to reset the electric windows.
- markyp2000
30 Sep 2012 14:34 #49150
by markyp2000
Replied by markyp2000 on topic Malfunction indicator light vvt engine
the engine light will come on for any component fault on the engine not just the o2 sensor iv never had to reset the windows?
- treasurer
30 Sep 2012 14:42 #49152
by treasurer
Replied by treasurer on topic Malfunction indicator light vvt engine
so how do you reset the windows ?
- markyp2000
30 Sep 2012 14:44 #49153
by markyp2000
pass like i said iv never hurd if it on a jimny
- treasurer
30 Sep 2012 14:44 #49154
by treasurer
the owners manual says it is a computer controlled emission control system malfunction
Time to create page: 0.157 seconds
