Oily ball joint on front axel.
  • Muzza904
22 Sep 2012 18:07 #48551 by Muzza904
Oily ball joint on front axel. was created by Muzza904
I was under my jimny today just having a look as you do and saw that my alloys and everything around the front axel ball joint thingy was covered in oil and road dirt etc. I can see that there is fresh oil as it has dripped slowly onto my tire leaving it streaky. Anyone ever had this before?
  • markyp2000
22 Sep 2012 18:12 #48552 by markyp2000
Replied by markyp2000 on topic Oily ball joint on front axel.
yer jack it up grab the wheel top and bottom and push and pull it top to bottom and see if you have play if you do it may be your king pins gone
  • Muzza904
22 Sep 2012 19:01 #48554 by Muzza904
Replied by Muzza904 on topic Oily ball joint on front axel.
Ok when I'm home tomorrow I'll try that and if it wobbles then what's the solution. I think maybe 2 years ago when it was in the garage for something I remember the mechanic saying he had spaced something with copper washers to stop a wobble, as a kind of temporary fix. Could that be related? And what is the best size to make your photos to upload them lol. I keep forgetting :huh:
  • Smoggy
22 Sep 2012 19:27 #48556 by Smoggy
Replied by Smoggy on topic Oily ball joint on front axel.
I keep my pics to about 2Mp
  • adamatdraycott
22 Sep 2012 20:11 - 22 Sep 2012 20:13 #48557 by adamatdraycott
Replied by adamatdraycott on topic Oily ball joint on front axel.
The copper washer thing will be to increase the load on the kingpin bearings... Which is a semi permanent fix to 'death wobble'
Oil dripping means means your axel/half shaft seals need replacing along with your king pin bearings.
Do not replace your king pins... Suzuki will insist these need changing @ £45 each and you need 4!
You need:
4 taper roller bearings (big jimny)
2 axel seals (big jimny)
2 ball joint seals (eBay)
Hylomar or similar sealant (big jimny or motor factors)
And some good quality waterproof bearing grease (big jimny)
Last edit: 22 Sep 2012 20:13 by adamatdraycott.
  • Muzza904
22 Sep 2012 20:13 #48558 by Muzza904
I'm doing this from my galaxy s3 is it worth getting tapatalk?
Time to create page: 0.188 seconds
