Clutch and fitting procedure
- jimnydms
12 Sep 2012 20:29 #48004
by jimnydms
Clutch and fitting procedure was created by jimnydms
hi i need to replace my clutch it was on its way out but with the big tyres and strain its pretty much gone,
any recommendations for a stronger than OEM clutch as i imagine the OEM clutch is not up for the job on big tyres lift crawler box and winching etc
any thoughts welcome please
can this be done from underneath? its on 235's and i got some big ramps to drive the front on to.
anythink i should look out for? procedure etc
cheers
cheers
- toph
12 Sep 2012 20:39 #48005
by toph
Replied by toph on topic Clutch and fitting procedure
Quite possibly the single most pain in the ass job I have done on my jimny!
If you have option of getting some one to do it for you I would let them loose the skin on the backs of their hand and bang their hand on the transfer box.
- jimnydms
12 Sep 2012 20:57 #48006
by jimnydms
Replied by jimnydms on topic Clutch and fitting procedure
great lol was the answer i was half expecting. what clutch did you fit?
- markyp2000
12 Sep 2012 21:51 #48012
by markyp2000
Replied by markyp2000 on topic Clutch and fitting procedure
try
www.rhinorays.co.uk see what he says
i did mine on my back didnt need to jack it up as i have a 4.5" lift what can i say never again one tip i can give you if you do it and its a single cam engine when you fit the clutch dont tighten the clutch bolt right up leave them loose so the plate just moves fit the gear box then where the clutch cable go on the fork you can get to the bolts only reason i did this was due to there being to studs on the engine and it stops you from twisting want wiggling the box up and down to get it on the splins if they are not ligned up good luck and enjoy
- jimnydms
12 Sep 2012 21:54 #48014
by jimnydms
im thinking maybe i ll get someone to do it for me lol sounds a bitch.
any thought s on what clutch, OEM or any uprated 4x4 clutch ?
- markyp2000
12 Sep 2012 22:08 #48016
by markyp2000
try the wed address i put up
Time to create page: 0.169 seconds
