Clutch and fitting procedure
- Basketcase
- Thank you received: 51
12 Sep 2012 22:18 #48018
by Basketcase
Replied by Basketcase on topic Clutch and fitting procedure
hi i had to change the clutch and gearbox on my jimny about a year ago now id never done anything this major before i had no idea what the hell i was doing to be honest but i managed to do it all and it was pretty easy i had no ramps only a small trolley jack small bottle jack and 2 axle stands lol. i had to remove the cat part of the exhaust and i struyggled like mad getting the gearbox in and out until i realised if you rotate it 90degrees it pretty much falls out. as for the clutch well alingning that was really simple, everyone told me (mainly mechanics from work) id really have trouble aligning it but as the box was out of the way i could sit up under the car and get my head in line with the engin/clutch and just managed to align it by eye that way. all in all i did it in about 8 hours but if i had to do it again now itd probably take me 5....just make sure you got a bloody good big pry bar and a decent socket set with a big long bar
hope this helps.....also i had no suspension lift at the time my jim was bog standard lol
The following user(s) said Thank You: jimnydms
- toph
13 Sep 2012 14:12 #48048
by toph
I took out a paddle clutch which was too harsh for greenlaning and replaced it with an exeddy normal one.
Replied by toph on topic Clutch and fitting procedure
jimnydms wrote: great lol was the answer i was half expecting. what clutch did you fit?
- jimnydms
13 Sep 2012 14:22 #48053
by jimnydms
Replied by jimnydms on topic Clutch and fitting procedure
cool, i have been doing some research on clutches and euro car parts stock exeedy, which i think has a good name and i can get it at 80+vat which is not too bad, think im going to have a crack at it myself lol
you ve found the exeedy one ok lasts ok and handles off road punishment ?
- Thank you received: 115
13 Sep 2012 16:06 #48069
by maverick
I quite AGREE - after messing around underneath and EVENTUALLY getting it fitted, i decided the NEXT time that I would:
a) Pay someone else to do it
b) Consider taking the engine out!
But will probably just do option a).
Jalapeño, IISY?
Replied by maverick on topic Clutch and fitting procedure
toph wrote: Quite possibly the single most pain in the ass job I have done on my jimny!
If you have option of getting some one to do it for you I would let them loose the skin on the backs of their hand and bang their hand on the transfer box.
Jalapeño, IISY?
- markyp2000
13 Sep 2012 17:03 #48072
by markyp2000
Replied by markyp2000 on topic Clutch and fitting procedure
when i did mine i just pulled the box bach and jacked it up to the floor thats why i couldnt line my clutch up
- VAXXi
14 Sep 2012 08:38 #48096
by VAXXi
Replied by VAXXi on topic Clutch and fitting procedure
Centerforce and Zanfi also make HD clutches.
Time to create page: 0.393 seconds
