tyres
- mudman
06 Sep 2012 20:37 #47674
by mudman
tyres was created by mudman
right this has probably been asked many times before but hay im new in the jimny world :laugh: so im planing a 2" spring lift, 2" body lift, 32mm spacers what is the tallest wheels i can go for without need transfer box mods cant quite afford that yet :laugh: i was thinking 235/75/15 i want to try and keep 15" rims if i can any help welcomed.
- reaper
06 Sep 2012 20:41 #47677
by reaper
Replied by reaper on topic tyres
You may need a little trimming of bumper and wheel arch just near door if your using the 32mm spacers with that size
- mudman
06 Sep 2012 20:47 #47678
by mudman
Replied by mudman on topic tyres
what would you say was best for that set up i don't mind a little trim but i don't want to start hacking out to much of the body
- myers647
06 Sep 2012 20:48 #47679
by myers647
Replied by myers647 on topic tyres
Hi mate the 235/75/15 will fit as thats what Iv always had but you will need to trim the arches front and back if your going to be off roading.
Thanks
James
Thanks
James
- mudman
06 Sep 2012 20:50 #47680
by mudman
well im not building it for a giggle :laugh: :laugh: :laugh:
myers647 wrote: Hi mate the 235/75/15 will fit as thats what Iv always had but you will need to trim the arches front and back if your going to be off roading.
Thanks
James
- reaper
06 Sep 2012 20:51 #47683
by reaper
Maybe a bit smaller as 235 75 15 is about the biggest you want to run on stock gearing , in an ideal world even stock 205 70 15 run better with a gear reduction
