diff leaking
- tenbob
06 Sep 2012 18:31 #47640
by tenbob
diff leaking was created by tenbob
firstly hi to all members im new to this site.i have just obtained my first jimny and need to do a few repairs .the main one is that there is diff oil leaking from the rear passenger side hub any ideas how this can be repaired and what i would need ie gasket seals etc and where would i obtain them i have not done anything like this before so all advice i would be greatfull for thanks.
- markyp2000
06 Sep 2012 18:48 #47642
by markyp2000
Replied by markyp2000 on topic diff leaking
fit a new wheel bearing and half shaft oil seal that comes in the kit
06 Sep 2012 22:39 #47697
by facade
Replied by facade on topic diff leaking
If you go to the home page, pick the "information" tab, then pick "how to guides" there is a pdf file on rear wheel bearings.
you will need a big vice and an angle grinder to get the old bearing off, or you can take the halfshaft and bearing to a garage to have a new one fitted.
Fitting the new one needs a press, or a scaffold tube and a hammer.
Time to create page: 0.166 seconds
