‘Malfunction Indicator Light’
- Tadpole
- Visitor
02 Dec 2012 19:07 #54682
by Tadpole
I like others have said, I would recommend a diagnostic check.
As to replacing the sensor not a big job, ten minutes however the right tool for the job is important imo ..
Replied by Tadpole on topic ‘Malfunction Indicator Light’
minibbb wrote: Thanks for the quick and helpful answer. Ill try disconnecting the battery first and failing that a mate at work has a diagnostics machine. Failing that its off to the garage!
Is it a big job actually replacing the sensor?
02 Dec 2012 19:48 #54687
by minibbb
Thanks matey much appreciate it, just gives me a a rough idea before I start investigations. Like you, mine seems to run fine so not too drastic, just don't like seeing warning lights!
Replied by minibbb on topic ‘Malfunction Indicator Light’
- Tadpole
- Visitor
02 Dec 2012 19:54 #54688
by Tadpole
Let us know how you get on, good luck .....
Time to create page: 0.162 seconds
