‘Malfunction Indicator Light’
  • Tadpole
  • Visitor
  • Visitor
29 Aug 2012 21:00 #47083 by Tadpole
Today I had an interior valet on my ‘new to me’ 2003 Jimny.
Now just by coincidence when I picked it up the ‘Malfunction Indicator Light’ came on & stayed on.
I have looked through the forum & found a couple of threads relating to this here.
www.bigjimny.com/index.php/forum/7-jimny...gine-light-coming-on
www.bigjimny.com/index.php/forum/7-jimny...-management-light-on
I intend to disconnect/re-connect the battery in the morning to clear the fault (I hope)
But I wonder, is it possible a strong ‘cleaner/solvent’ used to remove a bad oil stained carpet could set the fault?
Any ideas or advice welcome, thanks guys ... :)
  • markyp2000
  • Visitor
  • Visitor
29 Aug 2012 21:04 #47085 by markyp2000
Replied by markyp2000 on topic ‘Malfunction Indicator Light’
no i think its just coincidence just take it to a garage get it diagnosed and be done with it dont faf about doing this and that do it right first time and have it done and dusted
  • Tadpole
  • Visitor
  • Visitor
30 Aug 2012 17:39 - 30 Aug 2012 17:43 #47140 by Tadpole
Replied by Tadpole on topic ‘Malfunction Indicator Light’
As an update, this morning I disconnected/re-connect the battery which cleared the fault.
I then spent a couple of hours doing a few things to make this one mine.
The motor started without any reoccurrence of the fault light appearing even with multiple starts.
I’ll keep an eye on things as with only 36k on the clock I am hoping it was a one of ;)
Last edit: 30 Aug 2012 17:43 by Tadpole.
30 Aug 2012 18:54 #47151 by facade
If you have the twin cam engine, and intend keeping it, worth spending £20 on an OBD2 diagnostic reader from eBay, pays for itself the first time you use it.
Read any stored codes, and clear them to put the EML out.
(The reader will work in anything newer that you get in the future anyway)
The following user(s) said Thank You: Tadpole
  • Tadpole
  • Visitor
  • Visitor
30 Aug 2012 20:47 - 31 Aug 2012 08:04 #47176 by Tadpole
facade wrote: If you have the twin cam engine, and intend keeping it, worth spending £20 on an OBD2 diagnostic reader from eBay, pays for itself the first time you use it.
I do indeed have the twin cam engine.
Thanks for the advice & for that sort of money it sounds a good deal.
I have looked on the dbay however they all list as doing the same thing, some being manufacture linked.
Would it be possible to highlight a couple for consideration & I’ll make the purchase.
Cheers t …. ;)
Last edit: 31 Aug 2012 08:04 by Tadpole.
30 Aug 2012 23:06 #47187 by facade
I took my own advice, and ordered one of the £19.95 ones (+p&p:- b****r!)
I'll let you know if it works and which one when it arrives, hopefully Monday :)
