X-brake fitting.
- Smoggy
28 Aug 2012 22:37 - 29 Aug 2012 05:27 #47006
by Smoggy
Replied by Smoggy on topic X-brake fitting.
Sorry guys can someone give me an idiots step by step on exactly how to fit my xbrake (sorry Si im no great mechanic), I dont understand really how it stops the car and why does it go on the output to the rear wheels. Also on another issue how would I take apart my tbox to drill and tap it for a breather as the kit i have from Martin seems not to fit it (seems that pushfit fitting is too small to go over stub and supplied hose too big). If I decide on tapping in a breather is it a big job to split the case i.e. will I need to remove all the gearing with springs and washers popping out everywhere
Also now I am thinking with Si piloting a smaller disc version will the diameter of the disc on my xbrake foul my ORA tbox guard.
Sorry for all the questions.
Some picsof my setup:
Last edit: 29 Aug 2012 05:27 by Smoggy.
- markyp2000
28 Aug 2012 23:33 #47012
by markyp2000
Replied by markyp2000 on topic X-brake fitting.
on my tbox breather i got a bit of pipe that fitted over the stub and did the clip up very tight
- Smoggy
29 Aug 2012 10:57 #47035
by Smoggy
Yeah Marky just looked online at SJ tbox layout and it may be beyond me to take apart and modify.
- Smoggy
29 Aug 2012 18:02 #47053
by Smoggy
Just looked on Martins 'how to build rocklobster' thread and got a little more idea, is it possible to split the centre from the rear without first removing the front section and if so will this just pull away the rear of the case and leave all of the internals in place on the centre/front sections?
- Smoggy
16 Sep 2012 13:30 - 16 Sep 2012 13:46 #48189
by Smoggy
Still having problems fitting xbrake. I have removed the rear output drive flange and fitted my xbrake backplate to the box, but then faced with problem that because of the thickness and shape of the backplate my speedo correction bracket hole is now out of line with the toothed wheel which it reads. Also because of the shape of the backplate my correction bracket no longer bolts on in the same place without chopping or modifying it.
I will post some pics to illustrate what I mean.
Thanks in advance.
Also does somthing go onto the end of the plug in the last pic fir the speedo drive.
Thanks in advance.
Last edit: 16 Sep 2012 13:46 by Smoggy.
- Paul4x4
16 Sep 2012 14:10 #48192
by Paul4x4
Replied by Paul4x4 on topic X-brake fitting.
Just cut a speedo sensor bracket shaped piece off of that backplate, and weld the bracket in. Looks like an easy job to me...
Time to create page: 0.182 seconds
