X-brake fitting.
- Smoggy
27 Aug 2012 18:47 - 27 Aug 2012 19:26 #46911
by Smoggy
X-brake fitting. was created by Smoggy
Now got my new X brake from Si at X-eng and it really does look a great piece of kit. My question is when fitting my Xbrake to the rocklobster box is it advisable to do it with the box off the car or is it easy enough to do on the car?
Also when I removed the old T box the manual suggests making match marks on the shaft and box flanges for reassembly, why is this important cos I thought the props were all balanced anyway and if I am fitting a rocklobster is the rotation status of the props important?
Many Thanks.
Many Thanks.
Last edit: 27 Aug 2012 19:26 by Smoggy.
- X-Eng Simon
27 Aug 2012 20:01 #46920
by X-Eng Simon
Replied by X-Eng Simon on topic X-brake fitting.
Either or! Obviously, if the box is already out the truck doing anything is easier on a bench but it's not worth the hassle of removing it for the little you gain.
Don't know about the shafts - not something ive ever worried about. If you are pulling apart the expansion joint, mark the two halves so it goes back in the same orientation but I've never heard of it in relation to the flange.
Si
Si
27 Aug 2012 21:33 - 27 Aug 2012 21:35 #46930
by kirkynut
Replied by kirkynut on topic X-brake fitting.
Props are balanced with the splines lined up in one place and the UJ's are "in phase" so they can do their job proper like.
If you don;t put them back with the little dots on the props lined up they willbe out of balance as you have changed the poition of the balancing weight. It's a little similar to when they used to balance your car wheels on the car - it tookinto account the brake disc and hub too - so putting the wheel back on in a different place would change the balancing.
Simon, did you mention once upon a time that you might produce a different sized X Brake for the Jim Jam as it hangs down a little low on the Jim Jam compared with the SJ???
I might have imagined this but seem to hve itin my head for some reason.
Last edit: 27 Aug 2012 21:35 by kirkynut.
- Smoggy
27 Aug 2012 21:47 #46933
by Smoggy
Replied by Smoggy on topic X-brake fitting.
Sorry Kirky but I'm now even more confused. Where do I go then when I have fitted an SJ tbox and need to fit different props and even spacers to remake the diff/gearbox link up.
- X-Eng Simon
27 Aug 2012 22:46 #46936
by X-Eng Simon
I've been experimenting with a much smaller X-Brake which has an 11cm disk but the same stopping power as the current Defender. It's intended for Jeep, Toyota And Suzuki of course where the clearance is much more limited than on a Land Rover.
It's still at the first prototype stage but initial findings are good. It uses a completely custom Caliper so will need more testing than with one off the shelf - thus I have no idea when it will see the light of day!
Si
Si
27 Aug 2012 23:24 #46938
by kirkynut
Read Martin's How To guide on fitting an SJ transfer box to a Jimny to see what props you need but nonetheless, they all have little dots punched into them to line up if you split them so that they go back together right to keep them balanced.
Smoggy wrote: Sorry Kirky but I'm now even more confused. Where do I go then when I have fitted an SJ tbox and need to fit different props and even spacers to remake the diff/gearbox link up.
The following user(s) said Thank You: Smoggy
