exhaust fitting
- grumpy22
- Visitor
08 Aug 2012 19:53 #45743
by grumpy22
Replied by grumpy22 on topic Re: exhaust fitting
Thanks got that, I'm pretty clued up myself but this one has me and the chaps at ces stumped. All the right parts and gaskets and still cant get a good seal between the manifold and down pipe.
Sorted the rear box with shorter hanger rubbers so that doesn't bang anymore
Having the source of wisdom now ( beer!), will have another go tomorrow. Fitted loads of exhaust systems over the years and this has to be the fussiest!
Cheers
Cheers
- markyp2000
- Visitor
08 Aug 2012 22:45 #45758
by markyp2000
Replied by markyp2000 on topic Re: exhaust fitting
poorly made parts. get 2 down pipe to manifold gaskets and fit them both
- grumpy22
- Visitor
09 Aug 2012 08:18 #45770
by grumpy22
It's a crushable cone gasket about 15 mm deep, two wouldn't fit. You've given me an idea though, I'll try the centre section of a normal gasket between the manifold and cone to give an extra bit of squeeze.
Cheers
Cheers
- grumpy22
- Visitor
09 Aug 2012 15:10 #45788
by grumpy22
Did the trick-sorted for now at least!
Thanks for the ideas chaps
- goatboy
- Visitor
09 Aug 2012 15:19 #45790
by goatboy
What sort of gasket did you use? Paper one?
I really struggled to get the crushable gasket to fit too, think mine is still blowing a bit...
Replied by goatboy on topic Re: exhaust fitting
grumpy22 wrote: It's a crushable cone gasket about 15 mm deep, two wouldn't fit. You've given me an idea though, I'll try the centre section of a normal gasket between the manifold and cone to give an extra bit of squeeze.
Cheers
- grumpy22
- Visitor
09 Aug 2012 17:57 #45798
by grumpy22
No, I keep quite a few old ones 'just in case'. I think the one I used was from a mini (see avatar), it had a metal inner ring and two metal faces. I cut most of it away and just used it to push the cone gasket a little deeper into the down pipe ( did add the lightest smear of sealing paste too, but only at the top and well clear of the bores of the pipe)
Time to create page: 0.182 seconds
