exhaust fitting
- grumpy22
- Visitor
07 Aug 2012 10:54 - 07 Aug 2012 10:54 #45621
by grumpy22
exhaust fitting was created by grumpy22
can anyone tell me how many gaskets are needed to fit a full exhaust system?
fitted mine with the 'fitting kit' which only had one cone type crushable gasket between the cat and mid pipe. so it's blowing between the down pipe and mid pipe and back box.
98 G13B hardtop
thanks
98 G13B hardtop
thanks
Last edit: 07 Aug 2012 10:54 by grumpy22.
- Johnniehec
- Thank you received: 56
07 Aug 2012 11:41 #45626
by Johnniehec
Replied by Johnniehec on topic Re: exhaust fitting
Not sure Grumpy, but I usually re use the ones off the old system with a smear of exhaust assembly paste.
John.
John.
- grumpy22
- Visitor
07 Aug 2012 12:51 #45629
by grumpy22
Replied by grumpy22 on topic Re: exhaust fitting
Don't think there were any on the old system either but that was gas tight and the original system I think. I've fitted an aftermarket system which isn't quite as well fitting.
- markyp2000
- Visitor
07 Aug 2012 16:52 #45640
by markyp2000
Replied by markyp2000 on topic Re: exhaust fitting
just dont put any exhaust paste before the cat cos what squashes out squashes in and bits can fall off in side and get stuck in the cat a cause a hot spot and burn/melt some of the cat
- Johnniehec
07 Aug 2012 17:56 #45655
by Johnniehec
You learn something new every day, cheers Markyp2000.
Luckilly, when I think about it I've only put it after the cat on the ones I've done.
John.
markyp2000 wrote: just dont put any exhaust paste before the cat cos what squashes out squashes in and bits can fall off in side and get stuck in the cat a cause a hot spot and burn/melt some of the cat
John.
- markyp2000
- Visitor
08 Aug 2012 17:02 #45721
by markyp2000
well iv been working on cars for the past 16 years so if you have any questions or somthing your not shore on send me a message and ill see if i can help
Time to create page: 0.137 seconds
