transferbox seal
- stevedumptruck63
01 Aug 2012 19:14 #45270
by stevedumptruck63
transferbox seal was created by stevedumptruck63
hi guys,
i was under the jim on sunday pulling bits of grass and so forth from the underside after the weekend at holymoorside,and i noticed the rear seal is leaking on the transferbox,
is it a simple fix ?,looks like i would just have to remove the prop bolts,and then is it just a case of prying out the old seal and fitting the new one? thanks in advance steve :evil:
- reaper
01 Aug 2012 19:18 #45272
by reaper
Replied by reaper on topic Re: transferbox seal
May be easier to drop the box , getting the old one out is ok but putting the new one in can be tricky . Just make sure its going in square they like to go in wonky
- vitara_mad
01 Aug 2012 19:22 #45274
by vitara_mad
Replied by vitara_mad on topic Re: transferbox seal
it is slightly easyer with box off but you can do it with it on & it means less work :laugh:
remove prop bolts , then remove flange nut & flange off the box then you can get to the seal
- stevedumptruck63
01 Aug 2012 19:23 - 01 Aug 2012 19:25 #45275
by stevedumptruck63
Replied by stevedumptruck63 on topic Re: transferbox seal
thanks guys,sounds like a case of find the right size socket and be gentle with it :evil: steve.
Last edit: 01 Aug 2012 19:25 by stevedumptruck63.
