Height check!
- Smoggy
After chopping off the bumper extensions in preparation for my ORA bumper fitment and finding the damaged chassis legs. I have chopped out the cross-member ready to weld a new section and overweld/strengthen the chassis legs. The 2''bodylift is in place.
BUT on looking at the car from the front it looks really lopsided. I have taken measurements under the headlights, under the chassis legs and at wheelarch bottoms and the driver side is 1.5cm lower than the passenger side. I know it doesn't sound much but it looks worse
[attachment:1]2012-07-11 20.03.25.jpg[/attachment]
- stevedumptruck63
good tip - use spring compressors or straps to compress the spring ( i just needed to compress the middle 6 coils or so )
standard jimny - for now
- Smoggy
robs5230 wrote: i think you have the jimny lean . this will probably be more apparent on a lifted jimny . spring spacer from bits4vits fitted on top of the drivers front spring should straighten everything up .you will need to remove the rubber spring seat ( just pull it off ) and replace it with the spacer . before i fitted mine it felt like i was going to fall out of the drivers window. easy fix
Yeah im about to fit ORA 4.5'' lift kit anyway, so I might just fit spring spacers whilst im doing that. The only thing is with the 2'' bodylift I am conscious of getting too high
- reaper
Normally is say remove the bodylift then fit the ora kit but i have a feeling you will need both with those masooooove bead-locks :ohmy:
Not sure what if any problems you may get though
