Height check!
- chimpbikes
10 Jul 2012 21:33 #43919
by chimpbikes
Height check! was created by chimpbikes
Hello All,
I apologise if this is a silly question but I dont know the answer.
I bought a 2006 model with lots of good bits(winch, snorkel, spot lights) already on and it is raised up 3".
My question , how do you actually check the height, where do you measure (from where to where) to check if the actual raised height is 3 inches?
It does look high but i want to check before I start buying correction bushes, panhard rod mounting brackets etc. because it as none of these things.
It does have a steering damper and longer brake lines.
Thanks in advance,
Thanks in advance,
- supergaz
10 Jul 2012 22:03 #43925
by supergaz
Replied by supergaz on topic Re: Height check!
Park next to a standard jimny and get the tape measure out.
- goatboy
11 Jul 2012 06:58 #43932
by goatboy
Replied by goatboy on topic Re: Height check!
have a look here
bigjimny.com/index.php/forum/6-jimny-cha...w-tall-is-your-jimny
should be someone with a similar lift you can compare sizes with :whistle:
- chimpbikes
11 Jul 2012 12:16 #43950
by chimpbikes
Replied by chimpbikes on topic Re: Height check!
Thanks lads, I'm sure I'll get a good idea of the height now.
Cheers,
Cheers,
11 Jul 2012 12:50 #43953
by robs5230
standard jimny - for now
Replied by robs5230 on topic Re: Height check!
before you get the castor correction bushes , are there any problems when driving ? any vicious shake or wobble and does the steering wheel return to centre ?
- chimpbikes
11 Jul 2012 13:33 #43955
by chimpbikes
It does return to centre "ish" and the cornering can be a bit hairy/scary sometimes and it can be a bit lively driving at 60 on bumpy B roads.
Like I said above, I bought the Jimny 2nd hand and it has been raised a good height and I know the radius arms , bushes etc are all standard. Reading the threads on here I thought it would need "sorting" a little more.
I'm away offshore just now and cant measure the actual height (door handle rear light cluster)
Time to create page: 0.158 seconds
