Rocklobster fitting/propshafts
- Thank you received: 252
06 Jul 2012 20:46 #43623
by j999pre
Grey pick up Jimny
Rocklobster fitting/propshafts was created by j999pre
Finally fitted my rocklobster
Couple of questions for you.
The front SJ prop thats used as a rear looks very compressed. I probably have about a flange widths play left in compression is this ok?
Secondly how have people sealed up the sj speedo take off? Or does it even need doing?
Thanks
Thanks
Grey pick up Jimny
- suzuki jimny fella
06 Jul 2012 22:39 #43637
by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: Rocklobster fitting/propshafts
i stuck some grease in there and when i jet wash her i put more in the hole lol as check for damage on etc
- p1ngu32
09 Jul 2012 21:42 #43851
by p1ngu32
Replied by p1ngu32 on topic Re: Rocklobster fitting/propshafts
10 Jul 2012 08:35 #43858
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re: Rocklobster fitting/propshafts
I'm off to the diy shop after seeing that. Thanks
Mine has a 2" lift so maybe I need to think about going bigger to get a little more free play.
Grey pick up Jimny
- Johnniehec
- Thank you received: 56
10 Jul 2012 12:22 #43864
by Johnniehec
Replied by Johnniehec on topic Re: Rocklobster fitting/propshafts
Neat job P1ngu32, how are you doing? There's a BORDC trial at Lumsden on the 22nd, I'll not be there cos we're away on hols but it's not far from you.
Cheers,
John.
Cheers,
John.
- p1ngu32
10 Jul 2012 17:20 #43887
by p1ngu32
Cheers john, i'm good, won't be getting to any trials this year unfortunately, we have litterally just had our first baby so thats put things on hold for a wee while at least, some thing to think about for the future though!
you might be ok with the freeplay that you have, the axles tend to twist one way or the other so you would only ever be compressing one spring fully, you would possibly have to jump some thing with the jimny to compress both sides of the suspension enough to bottom out the prop.
Richard.
Richard.
Time to create page: 0.096 seconds
