3 inch lift !
01 Jul 2012 18:18 #43339 by robs5230
Replied by robs5230 on topic Re: 3 inch lift !
when lifted the axle will tilt making the shock bush sleeve at an angle to the shock mount on the axle . this would strain the bush and bolt. guess thats why so many bolts shear off when the relocation brackets aren't fitted. with the relocation bracket the bottom shock ring is turned 90 degrees to fit.
standard jimny - for now
  • Fearghal Murphy
01 Jul 2012 19:38 #43353 by Fearghal Murphy
Replied by Fearghal Murphy on topic Re: 3 inch lift !
Thanks rob for the info man ! I thought something like this might be the reason alright ! I raised up the front of the jimny to level things out and i lined em up all OK, however i have decided to go back standard for the moment until i get the relocation brackets ! May as well do things right ! Thanks everyone for advice ! Fabricator friend, shall be sorting the correction bus fitment with a press so very happy!
Cheers guys !
01 Jul 2012 20:29 - 01 Jul 2012 20:30 #43355 by robs5230
no worries mate , i have just fitted the relocation brackets ( from bigjimny shop ) . my bolts had sheared. you will need a good 12mm drill bit to drill ( i can recommend dewalt extreme ) the rest of the way through the mounting in the axle for the rear lower shock mounts and a good electric drill. buy the longer bolts from bigjimny shop at the same time as your brackets. when drilling use engine oil to cool. run at a low speed and it'll be through in no time. park your vehicle down hill and the oil will not run out when drilling.
the original bolts are prone to seizing in and snapping. get rid of them.
regards rob
Last edit: 01 Jul 2012 20:30 by robs5230.
Time to create page: 0.705 seconds
