3 inch lift !
  • Fearghal Murphy
  • Visitor
  • Visitor
28 Jun 2012 18:10 #43085 by Fearghal Murphy
3 inch lift ! was created by Fearghal Murphy
Hello again guys ! Just had my 3 inch lift kit from the bigjimny store delivered along with my extended brake lines ( many thanks to Martin for his patience) ! I have changed springs and shocks many times on cars before, but just wondering is there a sticky thread on here for a fitting guide , for visual assistance ?
Any help would be a great benefit ! I shud be ok regardless !
Thanks folks !
28 Jun 2012 18:19 - 28 Jun 2012 18:21 #43086 by dirtydogz
Replied by dirtydogz on topic Re: 3 inch lift !
Hi Fearghal
Fitting a 2"(50mm)or 3"(75mm) life.
If you got a set of longer brake hoses fit them first this is only with the 3"lift, not needed on the 2" lift.
You will need to fit some rear shock brackets, If you think you need them you can also fit a set of caster correction + adjustable pan-hard rods.
Next (WD 40) all the nuts and bolts on the shocks for about 2 days before starting.
Start with the rear first axle,undo the wheel nuts a little,then jack up on the axle or the chassis on both sides and lower on to axle stands as near to the radius arms as possible , so the tyres are about 2" off the ground,now remove the wheels.
Next place the trolley jack in the middle of the rear axle, jack it up so you can remove the nuts+bolts from the shocks.
Next lower the axle down keeping an eye on the brake pipe,(don't over stretch it if you are fitting the 2" lift.) next remove the old springs+shocks, you might need a mate to help you fit the new springs+shocks back on, or as l did a length of wood just to lever the axle down a little to get the new springs on.
Now do the the front the same way as the back, you will need to undo two bolts on the anti roll-bar.
If you need the axles to drop a little more you will need to remove one of the panhard rod bolts.
When your finished CHECK all the nuts +bolts+ wheel nuts are tight.
Hope this helps.
DIRTYDOGZ.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 28 Jun 2012 18:21 by dirtydogz.
  • Fearghal Murphy
  • Visitor
  • Visitor
28 Jun 2012 18:26 #43089 by Fearghal Murphy
Replied by Fearghal Murphy on topic Re: 3 inch lift !
Haha cheers Dogz, just actually read this on the chat page ha ! Thanks man ! Once i get the Jimny jacked up i shud be alright, will prob get a second set of hands from a bud who is a top mechanic/fabricator so a bit of experience there might be called upon ! Cheers man !
Are the castor correction bushes very hard to fit ? I have them here ready to go ! Glad i got em !
28 Jun 2012 19:04 - 28 Jun 2012 21:30 #43092 by dirtydogz
This might help you.
How to fit correction bushes.
If your mate is a mechanic he might have a bush press.
www.bigjimny.com/images/documents/fittin...orrection_bushes.pdf
Last edit: 28 Jun 2012 21:30 by dirtydogz.
  • Fearghal Murphy
  • Visitor
  • Visitor
01 Jul 2012 12:37 #43298 by Fearghal Murphy
Thanks again for all ur help dogz , just wondering about the rear shock brackets ?? are they essential ? or could i go ahead with the lift and fit them later after ordering more bits ?@
Thanks man !
01 Jul 2012 14:21 #43302 by dirtydogz
Yes it would be better to fit the brackets on your jimny.
