3 inch lift !
- Fearghal Murphy
- Visitor
01 Jul 2012 15:50 #43314
by Fearghal Murphy
Replied by Fearghal Murphy on topic Re: 3 inch lift !
Haha weather over there sounds good to me, bit bleak over here not looking good weather wise !
Yep i have paired back the rubber at the top so fits grand ! Now i cannot seem to get the bottom of the shocks to line up properly with the standard mounts
???? they are not lining up by bout 10 degrees ?
I have not fitted my castor correction bushes yet, big problem ?? Man if i ever bump into you, i shall buy you a crate of beer ! I need to get to my mates garage to fit the corrected bushes !
Muchas gracias !"
Muchas gracias !"
01 Jul 2012 16:10 - 01 Jul 2012 16:11 #43320
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: 3 inch lift !
Did the shock come with a fitting kit which will have a set of sleeve with a large size hole. if it did try one of them till you get so relocation brackets.
2002 JLX Soft Top
Last edit: 01 Jul 2012 16:11 by dirtydogz.
- Fearghal Murphy
- Visitor
01 Jul 2012 16:19 #43322
by Fearghal Murphy
No unfort not ! I think the answer is to fit the standard springs n shocks back on for the moment, be patient and order the relocation brackets ! Looking now i can see that w/o them the shock doesnt have too much space ! Damn it anyway ! I was hoping to go for a show drive 2moro !
Thanks again dogz, i owe ya and will get back onto you when i start again !
Sound !
Sound !
01 Jul 2012 16:27 #43323
by dirtydogz
2002 JLX Soft Top
Martin has them in stock for £26 so give him a bell.
2002 JLX Soft Top
01 Jul 2012 16:32 #43324
Replied by mlines on topic Re: 3 inch lift !
I am not sure what the problem is you are describing here? The shocks should fit, do you have a picture? You also ordered the slightly longer shocks so the brackets will make them longer again?
- Fearghal Murphy
- Visitor
01 Jul 2012 16:50 #43326
by Fearghal Murphy
Hi Martin !
I shall get a picture up 2moro morning !
Basically when i fit the top shock mount bolt it goes in fine. But when i line up the shock with the bottom mount they do not line up exactly and the bolt cannot be threaded through. I have tried to manipulate the axle position to get everything to line up, but still no joy
I am sure i am just missing something simple.
Thanks
Thanks
