Is this normal fuel consumption normal???
06 Jul 2012 16:49 #43606 by facade
Mine did about 25MPG, then one day I noticed that the fuel return line had a pinhole in it at the rusty bend behind the front wheel. Only leaked when the engine was running, fixing it got it back up to low 30s.
  • ne-crock
06 Jul 2012 17:03 #43607 by ne-crock
Replied by ne-crock on topic Re: Is this normal fuel consumption normal???
its terrible,
i'll give her a clean under and check for leaks she smells a bit of petrol when she's running but couldnt see any leaks when i looked
its a w reg softtop with 62k if that would make any difference
  • markyp2000
06 Jul 2012 17:15 #43608 by markyp2000
Replied by markyp2000 on topic Re: Is this normal fuel consumption normal???
i get about 170 miles to a tank but then i have a 6 point exo cage a winch and bumper plus the boot build all the weight added up and 195 80 15 a/t i should expect to lose a bit :lol:
06 Jul 2012 17:24 #43609 by mcjimny
Dan13l wrote: Yea I did and its just stats cold for ages then slowly starts to get warm but never to the point of not being able to touch it so I presume and hope that is the problem, but there is only one way to find out... Time to pull off the intake manifold :unsure:
It sounds like its stuck open then, good luck with it. Doesn't look as straightforward as most cars. :evil:
  • Dan13l
09 Jul 2012 12:04 #43789 by Dan13l
Hi all seemed to fix it a bit a changed the thermostat (that was a nightmare of a job) but while it was off I had the intake manifold blasted put to smooth all the imperfections out of the internal casting which has made a noticeable difference to performance and she now warms up in about 5-10min at idle (a bit different than an Hour) i haven done a full tank yet but I'm
At half a tank with 225km out of it so Better already :) I hope this was the issue
Time to create page: 0.187 seconds
